Good day Jude,
after creating the Users and the Samba share, the next thing to do in order to have the users get access to the created share, say: temp, is to configure the share.
- On the UMC, select Domain, and then Shares.
- Select (check the box) the share in question, and then the edit button.
In the General tab, make sure Domain Users is selected for the directory owner group. This is the default group every created user belongs to. You do this if you want user to have access to the share. If you are specific about who gets access to the share, then go to step 3 and 4. Else step 5.
- Select the Advanced options, and then the Samba permission. You set a screen similar to that below:
Enter the names of the users intended or group in the valid user or group field.The entries are to be separated by spaces. The special characters @, + and & can be used in connection with the group name for assigning certain
permissions to the users of the stated group for accessing the Samba share.
Under extended permissions you can fine tune the permissions settings
Further changes and configurations can be made as desired.
Do not forget to save your changes.
I believe the documentation below will be of help to you:
http://docs.software-univention.de/manual-4.2.html#shares::general
Best Regards
Anna
