Hi, I upgraded UCS to version 5.02, and all was fine then. but after some package updates I was not able to fetch E-Mails for new users via fetchmail. I notice that the fetchmailrc is not updated no matter what I fill in the forms under User.
When I manually insert the information in the fetchmailrc everything works as expected. I learn it has something to do with the listener, and in the listener.log I find
File "/usr/lib/univention-directory-listener/system/fetchmailrc.py", line 163, in handler
old = p.load()
TypeError: a bytes-like object is required, not 'str'
02.09.22 13:11:17.057 LISTENER ( WARN ) : handler: fetchmailrc (failed)
Does anybody has any ideas?
Thanks in advance
Christoph
