HI,
I have installed kopano Core with out any issues.
AS I tried to install the Kopano WebApp it seems that is running fine but at the end of the install I get an error message
During the installation I have seen that the Joint session has comming back at packed 71kopano4ucs-webapp returned the exitcode 1
Afterwards I can’t logon to the Kapano WebApp
releaing on the same issue.
And I still can’t login to the WebApp. I’ve uninstalled the webapp and updated the UCS and reinstalled the webapp but sitll the same issue.
BR
Stephan
Update
On a testsystem what I had used before, I installed ox and removed it, afterwards I installed Kopano Core and WebApp. I had no error messages and was able to access the WebGUI of Kopano.
But I run into other issues with the old OX stuff, which wasn’t easy to get rid of. So I setup a complete new environemt and run in to different issues.
yes definitely. I would even go so far to say that using the Kopano apps in a docker container is unsupported
Just install Univention in a virtualisation solution of your choice (and of course what is supported by Univention) and install Kopano through the Univention Appcenter.
Alternatively you can also grep one of the pre made app appliances, these have been recently updated to Univention 4.2. Kopano Core - Univention App Center
@fbartels:
The UCS server is installed with the ova file from the univention web site. All the installaiton I have done are done by the Appcenter.
But I’ll try the pre made one.
I’ll keep you updated.
Thanks & BR
Stephan
@fbartels:
I’ve downloaded the pre made kopano app and installed it on my ESX host, but I don’t have a pw to logon
I haven’t seen any how to or readme
If you could send me something would be appreciated.
@fbartels:
After some workarrounds, I have installed and configured Kopano and it works propperly.
have done the following steps to bring it up to speed:
Intstall the pre configured system as a stand alone server (with the same domain as my Domain)
tested the web app
joint the Domain
finish
thanks for your support
BR
Stephan
