Failed to load License - Invalid credentials
Can you please point me to the files or environment ucr variables that controls the success of the following error
ucr commit
File: /usr/share/univention-management-console/modules/apps.xml
04.08.15 16:03:39.247 MODULE ( WARN ) : Failed to load license information: {‘desc’: ‘Invalid credentials’}
          How can I reset this passwords or credentials  via console.
Rolando Riley
the only official component using credentials I am aware of is Open-Xchange.
Are you using a commercial subscription or the community version of OX?
Best Regards,
Dirk Ahrnke
Commercial Subscription.
Rolando Riley
I’d check (or maybe better renew) the credentials in the “OX License Management” module.
I am running an upgrade to try to get rid of some of the errors the server is dropping. I am also seeing invalid credentials while performing this task
oot@mail:~# univention-upgrade --ignoreterm --ignoressh
Starting univention-upgrade. Current UCS version is 3.2-6 errata340
Checking for release updates: found: UCS 4.0-0
Do you want to update to 4.0-0 [Y|n]? Y
Starting update to UCS version 4.0-0
HINT:
Please check the release notes carefully BEFORE updating to UCS 4.0-0:
English version: docs.univention.de/release-notes-4.0-0-en.html
German version: docs.univention.de/release-notes-4.0-0-de.html
3rd party components.
Do you want to continue [Y/n]? Y
ldap_bind: Invalid credentials (49)
     The following command is running nice  over /etc/ldap.secret
       ldapsearch -h localhost -p 7389 -x -D cn=admin,$(ucr get ldap/base) -w $(cat /etc/ldap.secret) cn=admin
        univentionLicenseSupport: 0
univentionLicenseType: UCS
univentionLicenseUsers: unlimited
univentionLicenseVersion: 2
univentionLicenseVirtualDesktopClients: 0
univentionLicenseVirtualDesktopUsers: 0
univentionObjectType: settings/license
search result
search: 2
result: 0 Success
numResponses: 3
numEntries: 2
R Riley
Anyone has an answer as to why it fails to bind during upgrade?
Rolando
Hello?
Regarding: “ldap_bind: Invalid credentials (49)”
Unfortunately slapd always returns “Invalid credentials” in case of failed bind for security reasons. See here: openldap.org/faq/data/cache/231.html
I would first check the credentials and the bindDN as suggested in the link.
Thanks winter,
My previous email shows a successful query for ldapsearch.
ldapsearch -h mail.airesistemas.com -p 7389 -x -D cn=admin,$(ucr get ldap/base) -w $(cat /etc/ldap.secret) cn=admin
search result
search: 2
result: 0 Success
numResponses: 3
numEntries: 2
                 What is the script that might be parsing incorrectly hostdn/domaindn on  this attempt to bind when issuing          univention- pgrade.       Are there any UCR variable I should revise?
Rolando Riley
ucr get connector/ldap/binddn
should be the same as
ucr get ucr get ldap/hostdn
If that is not the case you can do
ucr set connector/ldap/binddn=$(ucr get ldap/hostdn) invoke-rc.d univention-s4-connector restart
Winter,
I found the line that is giving me problems with authentication on one of the scripts. Problem is on /etc/machine.secret
ldapsearch -x -ZZ -D “$ldap_hostdn” -y /etc/machine.secret ‘(&(univentionService=Samba 3)(objectClass=univentionDomainController))’ -LLL dn | ldapsearch-wrapper | sed -ne ‘s|dn: ||p’
this line was found on the scripts /usr/lib/univention-install/96univention-samba4.inst
Module: ox-config
Multifile: /etc/samba/smb.conf
Stopping NTP server: ntpd.
Starting NTP server: ntpd.
Restarting univention-directory-listener daemon.
ok: run: univention-directory-listener: (pid 18370) 0s, normally down
done.
Calling joinscript 96univention-samba4.inst …
File “”, line 4, in
         How do I update  this secret so it lets me authenticate???
Like I’ve said in the other thread you’ve opened a couple of days ago: the computer account might not actually exist anymore. Please verify that it still exist. You can use the cn=admin… DN for authentication as you’ve shown that this still works. Something like the following should show the computer’s object:
ldapsearch -h $(ucr get ldap/master) -p 7389 -x -D cn=admin,$(ucr get ldap/base) -w $(cat /etc/ldap.secret) -b $(ucr get ldap/hostdn)
If that computer account still exists then you might be able to change the passwort to the one that is currently stored in /etc/machine.secret. Note that I haven’t tried this myself. The command would look something like this:
ldappasswd -h $(ucr get ldap/master) -p 7389 -x -D cn=admin,$(ucr get ldap/base) -w $(cat /etc/ldap.secret) -s $(cat /etc/machine.secret) $(ucr get ldap/hostdn)
Verify the success by running the command you’ve found failing before.
If, on the other hand, the computer account does not exist anymore then I suggest restoring from backups.
In any case this amounts to mucking about with the innards of a sensitive system. I highly suggest you obtain professional support from Univention for clearing this up in case the manual password change mentioned above doesn’t work.
Dear Moritz,
         Thank you  for your help.   Here is how to replicate this problem
              1)  [wiki.univention.de/index.php?tit ... nd_Restore](http://wiki.univention.de/index.php?title=Single_Server_Backup_and_Restore)
              2)  Hostname can't be the same as domain name according Samba4;  This wasn't prevented on earlier version of UCS
              3)  Server requires either hostname change or migration for further upgrades
              4)  The new name of the computer [b]does not match[/b] previous name when performing  step 1)   resulting on  invalid credentials  == > due to 32 No Such Object
           Professional help is given here.  That is what I understand this forum is for  and you guys are
thanks,
Rolando Riley
Dear Mr. Riley,
We would like to help you with your issue and follow the forum regularly, unfortunatly we are at a point, where the forum is not the best means to this end.
We conferenced with our partner and we would like to help you with a reference to Mr. Bunkus - Linet. I will send the contact- data via private message. I am sure that is way more helpfull then forum messages at this point.
Kind regards,
Jens Thorp-Hansen
Head of Support
Univention GmbH
Hello Guys,
Problem was fixed. Created a new ldif with the matching current name. Afterwards, reinstalled some packages that were giving problems ( samba4, cyrus, postfix).
ldapadd -x -D “cn=admin,$(ucr get ldap/base)” -w “$(cat /etc/ldap.secret)” -f machine.txt
        The above command did the trick.
thanks,
Rolando Riley
