Hello
I have problem with execute join script I try to force execute but no succuss
Here is log file
join.log (180.0 KB)
Can any one help me to resolve the problem because I try to install new application but can not install new app problem was caused by Join failed
10518 actions.install.container.857e 18-10-04 11:23:29 [ INFO]: Joining
10518 actions.install.container.857e 18-10-04 11:23:29 [ INFO]: univention-join: joins a computer to an ucs domain
10518 actions.install.container.857e 18-10-04 11:23:29 [ INFO]: copyright (c) 2001-2018 Univention GmbH, Germany
10518 actions.install.container.857e 18-10-04 11:23:30 [ INFO]: Search DC Master: done
10518 actions.install.container.857e 18-10-04 11:23:35 [ INFO]: Check DC Master: done
10518 actions.install.container.857e 18-10-04 11:24:21 [ INFO]: Search ldap/base done
10518 actions.install.container.857e 18-10-04 11:24:24 [ INFO]: Search LDAP binddn done
10518 actions.install.container.857e 18-10-04 11:24:27 [ INFO]: Join Computer Account: done
10518 actions.install.container.857e 18-10-04 11:25:57 [ WARNING]: ldap_start_tls: Connect error (-11)
10518 actions.install.container.857e 18-10-04 11:25:57 [ WARNING]: additional info: TLS: hostname does not match CN in peer certificate
10518 actions.install.container.857e 18-10-04 11:25:57 [ INFO]: Check TLS connection:
10518 actions.install.container.857e 18-10-04 11:25:57 [ INFO]: **************************************************************************
10518 actions.install.container.857e 18-10-04 11:25:57 [ INFO]: * Join failed! *
10518 actions.install.container.857e 18-10-04 11:25:57 [ INFO]: * Contact your system administrator *
10518 actions.install.container.857e 18-10-04 11:25:57 [ INFO]: * Message: Establishing a TLS connection with ucs.domain.la failed. Maybe you didn't specify a FQDN.
10518 actions.install.container.857e 18-10-04 11:25:57 [ WARNING]: Something went wrong while joining the system
10518 actions.install.container.857e 18-10-04 11:25:57 [ WARNING]: sed: can't read /etc/php/7.0/apache2/php.ini: No such file or directory
10518 actions.install.container.857e 18-10-04 11:25:58 [CRITICAL]: Something went wrong while joining the system
10518 packages 18-10-04 11:25:58 [ DEBUG]: Releasing LOCK
10518 actions.install 18-10-04 11:25:58 [CRITICAL]: Setup script failed!
10518 actions.install 18-10-04 11:25:58 [ WARNING]: Aborting...
10518 actions.remove 18-10-04 11:25:58 [ DEBUG]: Calling remove
Thank you
Best regards
