here
https://wiki.univention.de/index.php/Integration_with_UCS/Attributes
OID is explained like this:
(advanced) A unique (world wide!!) identifier for the attribute. As Univention has its own namespace of OIDs, the App Center can generate unique OIDs automatically
so what can I do if I don’t have an app but just want to expand my LDAP for an app running somewhere else?
I thought I can just modify the schema of “Nextcloud” from “/var/lib/univention-ldap/local-schema/nextcloud.schema”
and then just import it like this:
ucs_registerLDAPExtension --schema /tmp/mypackagename.schema --packagename mypackagename --packageversion
1
is this possible, as soon as I find out what OID I can use?
