Hi, some months ago I’ve unistalled nagios.
Now I want to reinstall it, but univention-install nagios ----> few errors:
Not replacing deleted config file /etc/nagios/apache2.conf
enabling Apache2 config...
ERROR: Conf nagios3 does not exist!
apache2_invoke cgi: already enabled
dpkg: errore nell'elaborare il pacchetto nagios-cgi (--configure):
dpkg: errore nell'elaborare il pacchetto nagios (--configure):
dependences problems
File "/usr/sbin/univention-pkgdb-scan", line 37, in <module>
univention.pkgdb.main()
File "/usr/lib/python2.7/dist-packages/univention/pkgdb.py", line 579, in main
connection = open_database_connection(config_registry, pkgdbu=False)
File "/usr/lib/python2.7/dist-packages/univention/pkgdb.py", line 561, in open_database_connection
connection = pgdb.connect(database=connectstring)
File "/usr/lib/python2.7/dist-packages/pgdb.py", line 1615, in connect
cnx = _connect(dbname, dbhost, dbport, dbopt, dbuser, dbpasswd)
pg.InternalError: FATALE: authentication failed user "DChostname$"
How can I fix its?
Thank you
Regards
