I’m seeing rejects in the
/var/lib/univention-connector/ad/
all of them see to be exactly the same error.
related to changing a group name from
" gpc office"
to
“gpc-office”
dover11.09.2020 06:25:17.140 MAIN (------ ): DEBUG_INIT
11.09.2020 06:25:17.234 LDAP (PROCESS): Building internal group membership cache
11.09.2020 06:25:17.425 LDAP (PROCESS): Internal group membership cache was created
11.09.2020 06:25:17.501 LDAP (PROCESS): Using zx01 as AD Netbios domain name
11.09.2020 06:25:18.121 LDAP (PROCESS): sync from ucs: Resync rejected file: /var/lib/univention-connector/ad/1599730906.256689
11.09.2020 06:25:18.167 LDAP (PROCESS): sync from ucs: [ user] [ modify] cn=ben.dover,ou=pd manager (d),ou=merchandising,ou=gpc office,DC=zx01,DC=org,DC=donalds,DC=com
11.09.2020 06:25:18.214 LDAP (WARNING): sync failed, saved as rejected
11.09.2020 06:25:18.216 LDAP (WARNING): Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/univention/connector/__init__.py", line 803, in __sync_file_from_ucs
or (not old_dn and not self.sync_from_ucs(key, object, premapped_ucs_dn, old_dn, object_old))):
File "/usr/lib/python2.7/dist-packages/univention/connector/ad/__init__.py", line 2617, in sync_from_ucs
self.lo_ad.lo.add_s(compatible_modstring(object['dn']), compatible_addlist(addlist)) # FIXME encoding
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 210, in add_s
return self.result(msgid,all=1,timeout=self.timeout)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 503, in result
resp_type, resp_data, resp_msgid = self.result2(msgid,all,timeout)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 507, in result2
resp_type, resp_data, resp_msgid, resp_ctrls = self.result3(msgid,all,timeout)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 514, in result3
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 521, in result4
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 106, in _ldap_call
result = func(*args,**kwargs)
NO_SUCH_OBJECT: {'info': "0000208D: NameErr: DSID-0310020A, problem 2001 (NO_OBJECT), data 0, best match of:\n\t'DC=zx01,DC=org,DC=donalds,DC=com'\n", 'matched': 'DC=zx01,DC=org,DC=donalds,DC=com', 'desc': 'No such object'}
