Error upgrade from 4.4.3 errata587
Hello
i’m not it expert but all my platform with only nextcloud installed is stuck in maintenance mode and UCS cannot upgrade this is the log file
28.01.21 11:34:45.481 DEBUG_INIT
**** Starting univention-updater with parameter=[’/usr/share/univention-updater/univention-updater’, ‘net’, ‘–updateto’, ‘4.4-7’, ‘–ignoressh’, ‘–ignoreterm’]
Version=4.4
Patchlevel=3
starting net mode
—>DBG:update_available(mode=net, cdrom_mount_point=/media/cdrom, iso=None)
Checking network repository
Update to = 4.4-4
**** Downloading scripts at Thu Jan 28 11:34:46 2021
**** Starting actual update at Thu Jan 28 11:34:48 2021
Running preup.sh script
gio 28 gen 2021, 11.34.48, CET
HINT:
Please check the release notes carefully BEFORE updating to UCS 4.4-4:
English version: https://docs.software-univention.de/release-notes-4.4-4-en.html
German version: https://docs.software-univention.de/release-notes-4.4-4-de.html
3rd party components.
Do you want to continue [Y/n]?
Custom preupdate script /var/lib/local-preup.sh not found
Checking for space on /var/cache/apt/archives: OK
Checking for space on /boot: OK
Checking for space on /: OK
Checking for package status: rF mariadb-server-10.0 10.0.36-0+deb8u1 amd64 MariaDB database server binaries
failed
ERROR: The package state on this system is inconsistent.
Please run ‘dpkg --configure -a’ manually
Error: Update aborted by pre-update script of release 4.4-4
