Error Univention Domain Join (ntpdate)
Hi, I’ve installed the Univention Domain Join, but when i set the command:
sudo univention-domain-join-cli --skip-login-manager
Is generated this log:
2019-12-27 08:48:09,341 userinfo INFO Automatically detected the domain 'ifbaiano.si.intranet'.
2019-12-27 08:48:26,075 userinfo WARNING Warning: /etc/resolvconf/resolv.conf.d/base already exists.
2019-12-27 08:48:26,076 userinfo WARNING Warning: /etc/ldap/ldap.conf already exists.
2019-12-27 08:48:26,076 userinfo WARNING Warning: /etc/sssd/sssd.conf already exists.
2019-12-27 08:48:26,095 userinfo WARNING Warning: /etc/auth-client-config/profile.d/sss already exists.
2019-12-27 08:48:26,096 userinfo WARNING Warning: /usr/share/pam-configs/ucs_mkhomedir already exists.
2019-12-27 08:48:26,096 userinfo WARNING Warning: /usr/share/pam-configs/local_groups already exists.
2019-12-27 08:48:26,097 userinfo WARNING Warning: /etc/krb5.conf already exists.
2019-12-27 08:48:26,097 userinfo INFO Created a backup of all configuration files, that will be modified at '/var/univention-backup/20191227114826_domain-join'.
2019-12-27 08:48:26,115 userinfo INFO "prepend domain-name-servers" already in /etc/dhcp/dhclient.conf
2019-12-27 08:48:26,691 userinfo INFO Writing /etc/resolvconf/resolv.conf.d/base
2019-12-27 08:48:26,692 userinfo INFO Applying new resolvconf settings.
2019-12-27 08:48:36,010 userinfo INFO Updating old LDAP entry for this machine on the DC master
2019-12-27 08:48:39,639 userinfo INFO Writing /etc/ldap/ldap.conf
2019-12-27 08:48:39,639 userinfo INFO Writing /etc/machine.secret
2019-12-27 08:48:39,642 userinfo INFO Writing /etc/sssd/sssd.conf
2019-12-27 08:48:40,807 userinfo INFO Writing /etc/auth-client-config/profile.d/sss
2019-12-27 08:48:40,807 userinfo INFO Configuring auth config profile for sssd
2019-12-27 08:48:40,912 userinfo INFO Restarting sssd
2019-12-27 08:48:42,115 userinfo INFO Writing /usr/share/pam-configs/ucs_mkhomedir
2019-12-27 08:48:42,115 userinfo INFO Adding  groups to /usr/share/pam-configs/local_groups
2019-12-27 08:48:42,116 userinfo INFO Updating PAM
2019-12-27 08:48:43,407 userinfo INFO Writing /etc/krb5.conf
2019-12-27 08:48:43,408 userinfo INFO Synchronizing time with the DC master
2019-12-27 08:48:51,526 userinfo CRITICAL An error occurred. Please check /var/log/univention/domain-join-cli.log for more information.
2019-12-27 08:48:51,526 debugging CRITICAL Command '['ntpdate', '-bu', 'scd03si.ifbaiano.si.intranet']' returned non-zero exit status 1
  File "/usr/sbin/univention-domain-join-cli", line 195, in <module>
    distribution_joiner.join_domain()
  File "/usr/lib/python2.7/dist-packages/univention_domain_join/distributions/ubuntu.py", line 101, in join_domain
    KerberosConfigurator().configure_kerberos(self.kerberos_realm, self.master_ip, self.ldap_master)
  File "/usr/lib/python2.7/dist-packages/univention_domain_join/join_steps/kerberos_configurator.py", line 65, in configure_kerberos
    self.synchronize_time_with_master(ldap_master)
  File "/usr/lib/python2.7/dist-packages/univention_domain_join/utils/general.py", line 40, in root_wrapper
    return_value = func(*args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/univention_domain_join/join_steps/kerberos_configurator.py", line 104, in synchronize_time_with_master
    stdout=OUTPUT_SINK, stderr=OUTPUT_SINK
  File "/usr/lib/python2.7/subprocess.py", line 540, in check_call
    raise CalledProcessError(retcode, cmd)
CalledProcessError: Command '['ntpdate', '-bu', 'scd03si.ifbaiano.si.intranet']' returned non-zero exit status 1
And i don’t know how to fix it. Somebody could help?
