[code]ldap.INVALID_CREDENTIALS: {‘desc’: ‘Invalid credentials’}
Restarting Name Service Cache Daemon: nscd.
setfacl: Option -m: Invalid argument near character 3
Error: Could not set fACL for /var/lib/samba/sysvol
EXITCODE=2
RUNNING 97univention-s4-connector.inst
2015-12-02 03:13:11.229344481+02:00 (in joinscript_init)
File “”, line 4, in
File “/usr/lib/pymodules/python2.7/univention/lib/admember.py”, line 133, in is_domain_in_admember_mode
lo = univention.uldap.getMachineConnection()
File “/usr/lib/pymodules/python2.7/univention/uldap.py”, line 101, in getMachineConnection
lo=access(host=ucr[‘ldap/master’], port=port, base=ucr[‘ldap/base’], binddn=ucr[‘ldap/hostdn’], bindpw=bindpw, start_tls=start_tls, decode_ignorelist=decode_ignorelist, reconnect=reconnect)
File “/usr/lib/pymodules/python2.7/univention/uldap.py”, line 177, in init
self.__open(ca_certfile)
File “/usr/lib/pymodules/python2.7/univention/uldap.py”, line 219, in __open
self.lo.simple_bind_s(self.binddn, self.__encode_pwd(self.bindpw))
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 879, in simple_bind_s
res = self._apply_method_s(SimpleLDAPObject.simple_bind_s,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 860, in _apply_method_s
return func(self,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 215, in simple_bind_s
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 476, in result3
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 483, in result4
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 106, in _ldap_call
result = func(*args,**kwargs)
Not updating connector/s4/ldap/host
Not updating connector/s4/ldap/base
Not updating connector/s4/ldap/ssl
Not updating connector/s4/mapping/group/language
Not updating connector/s4/ldap/protocol
Not updating connector/s4/ldap/socket
authentication error: Authentication failed
EXITCODE=3
Wed Dec 2 03:13:12 EET 2015
/usr/share/univention-directory-manager-tools/univention-dnsedit: timeout while trying to contact LDAP server[/code]
