when trying to install horde show an error and installation cancelled
Log:
Join Computer Account: done
chmod: cannot access '/etc/univention/ssl/ucsCA/CAcert.pem': No such file or directory
ldap_start_tls: Connect error (-11)
Check TLS connection:
* Join failed! *
* Contact your system administrator *
* Message: Please visit https://help.univention.com/t/8842 for common problems during the join and how to fix them -- Establishing a TLS connection with ucs-4821.hussain.local failed. Maybe you didn't specify a FQDN.
Something went wrong while joining the system
Setup script failed!
Aborting...
Going to remove Horde Groupware Webmail Edition (5.2.17-3)
as https://help.univention.com/t/8842 for hussain.local
# host -t SRV "_domaincontroller_master._tcp.$domainname"
Host _domaincontroller_master._tcp. not found: 3(NXDOMAIN)
Best Regards
