Error in join-script after upgrading Opsi from 4.2 to 4.3
Hi @all,
yesterday i have updated our main DC to 5.0-6 errata951 and after that i upgraded opsi from 4.2 to 4.3.
The installations runs without errors but the join-script 99opsi4ucs runs into a failure.
The main DC is our opsi configserver we got several slave DCs with opsi-depots.
Here is the output of the join.log:
Do 8. Feb 11:41:12 CET 2024
univention-join-hooks: looking for hook type "join/pre-joinscripts" on srv-ucs-asl.schule.local
Found hooks:
RUNNING 99opsi4ucs.inst
2024-02-08 11:41:13.467652005+01:00 (in joinscript_init)
Running on domaincontroller_master
Testing ldap connection to srv-ucs-asl.schule.local
Found configserver: srv-ucs-asl.schule.local
Hostname in global.conf: "srv-ucs-asl.schule.local"
System information
     UCS version      : 5.0
     UCS patchlevel   : 6
     UCS role         : domaincontroller_master
     Opsi server role : configserver
     Root dn          : dc=schule,dc=local
     LDAP master      : srv-ucs-asl.schule.local
     LDAP user        : cn=srv-ucs-asl,cn=dc,cn=computers,dc=schule,dc=local
     Hostname         : srv-ucs-asl
     Domain           : schule.local
     FQDN             : srv-ucs-asl.schule.local
     IP-Address       : 172.16.2.1
     Netmask          : 255.255.255.0
     Gateway          : 172.16.2.254
     Subnet           : 172.16.2.0
     Broadcast        : 172.16.2.255
     Windomain        : SCHULE
     OPSI UCS APP     : installed
Object not found: cn=opsiHostId,cn=custom attributes,cn=univention,dc=schule,dc=local
Adding system users and groups...
No modification: cn=OPSI Depot Servers,cn=groups,dc=schule,dc=local
WARNING: cannot append cn=srv-ucs-asl,cn=dc,cn=computers,dc=schule,dc=local to hosts, value exists
Adding system users and group: opsifileadmins
Checking if pcpatch group exists
Result: 0
No modification: cn=opsiadmin,cn=groups,dc=schule,dc=local
WARNING: cannot append uid=opsiconfd,cn=users,dc=schule,dc=local to users, value exists
Adding Administrator to opsiadmin
WARNING: cannot append uid=Administrator,cn=users,dc=schule,dc=local to users, value exists
Adding Administrator to opsifileadmins
No modification: cn=opsifileadmins,cn=groups,dc=schule,dc=local
Waiting for opsi groups to be synced:Groups are synced.Creating container for samba shares
Object exists: cn=srv-ucs-asl.schule.local,cn=shares,dc=schule,dc=local
Failed to reload smbd.service: Unit smbd.service is masked.
Waiting for samba shares
Setting samba/acl/allow/execute/always=true
Multifile: /etc/samba/smb.conf
Setting samba4/ntacl/backend
File: /etc/samba/base.conf
Configuring opsi
Skip samba in opsiconfd setup
Checking security options for opsi
Setting security/packetfilter/package/opsi4ucs/tcp/4447/all
File: /etc/security/packetfilter.d/10_univention-firewall_start.sh
File: /etc/security/packetfilter.d/80_univention-firewall_policy.sh
Setting security/packetfilter/package/opsi4ucs/udp/69/all
Setting security/packetfilter/package/opsi4ucs/tcp/4447/all/en
Setting security/packetfilter/package/opsi4ucs/udp/69/all/en
Setting security/packetfilter/package/opsi4ucs/tcp/3000/all
Setting security/packetfilter/package/opsi4ucs/tcp/3000/all/en
Cleanup old opsi local-Filterrules
opsi-server dpkg status: install ok installed
opsiconfd dpkg status install ok installed
Check for opsi fileadmingroup:OK
Running opsiconfd setup...
  File "run-opsiconfd.py", line 10, in <module>
  File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
  File "PyInstaller/loader/pyimod02_importers.py", line 419, in exec_module
  File "opsiconfd/__main__.py", line 11, in <module>
  File "opsiconfd/main.py", line 33, in <module>
  File "opsiconfd/application/__init__.py", line 31, in <module>
  File "opsiconfd/config.py", line 1436, in <module>
  File "opsiconfd/utils.py", line 78, in __call__
  File "opsiconfd/config.py", line 259, in __init__
  File "opsiconfd/config.py", line 298, in _set_args
  File "opsiconfd/config.py", line 319, in _parse_args
  File "opsiconfd/config.py", line 370, in _update_config
  File "urllib/parse.py", line 395, in urlparse
  File "urllib/parse.py", line 500, in urlsplit
  File "urllib/parse.py", line 446, in _check_bracketed_host
  File "ipaddress.py", line 54, in ip_addressss
ValueError: 'samba' does not appear to be an IPv4 or IPv6 address
EXITCODE=1
3bf3f2aa-bde1-4576-b2c9-a60254541185
univention-join-hooks: looking for hook type "join/post-joinscripts" on srv-ucs-asl.schule.local
Found hooks:
I cant find out where the script get “samba” as an IP.
just guess into the blue…
Maybe the firewall is the problem,
Good evening Mr. W.B.
No its not the firewall.
So what was it?
Heard from the blue, you solved the problem,
would be nice to share it here
This is the solution.
https://forum.opsi.org/viewtopic.php?t=13897
