After some research, I found that the following excerpt from template file /etc/univention/templates/files/etc/postfix/main.cf.d/10_general:
# some basic mail system settings
myhostname = @%@hostname@%@.@%@domainname@%@
# mydomain is unset - The default is to use $myhostname minus the first component.
fqdn = '%s.%s' % (configRegistry.get('hostname'), configRegistry.get('domainname'))
if configRegistry.get('mail/postfix/myorigin'):
print('myorigin = %s' % configRegistry['mail/postfix/myorigin'])
else:
print('myorigin = %s' % fqdn)
print('smtp_helo_name = %s' % configRegistry.get('mail/smtp/helo/name', fqdn))
# banner
if configRegistry.get('mail/postfix/smtpd/banner'):
print('smtpd_banner = %s' % configRegistry['mail/postfix/smtpd/banner'])
Gets correctly translated into /etc/postfix/main.cf as:
myhostname = ucs1.commonsenseit.ca
myorigin = ucs1.commonsenseit.ca
smtp_helo_name = commonsenseit.ca
# banner
smtpd_banner = commonsenseit.ca
http://www.postfix.org/postconf.5.html says that smtp_helo_name is "The hostname to send in the SMTP HELO or EHLO command. " which is a client (smtp) feature and nothing to be shown while connecting to postfix acting as a server (smtpd).
This means that smtp_helo_name will never change the EHLO-response.
As far as I remember the only chance to change this response would be to alter myhostname but this may have undesired side effects for example on mydestination.
In addition, myhostname defaults hardcoded to the real hostname itself. This could be addressed by following https://docs.software-univention.de/manual-5.0.html#mail::serverconfig::maincflocal
The next sentence on the same document you refer states “The default value is the machine hostname. Specify a hostname or [ip.add.re.ss]”.
For my perspective, this means the once smtp_helo_name is changed, its new value would be sent as EHLO-response.
What would be the point of modifying a configuration variable, if its new value is not going to be used?
The basic misunderstanding here is that smtp_helo_name is what Postfix uses as a HELO/EHLO response, when in fact it describes what Postfix sends in the HELO/EHLO command, as @ahrnke already quoted from the postconf document.
What Postfix sends as a response is being defined in smtp_banner.
