Egroupware ucs5
I am trying to get egroupware working on my UCS server. When I got it installed and trying going to my site:
https://10.10.10.10/egroupware/index.php
After trying to configure it in the egroupware page when I open it. are they any documented work around or ways to integrate this from a docker-compose.yaml?
The main issue is when I create a user in the user section, I can login but I am not seeing anything but the but the very top menu and its is not consistent when I create users. user A with all groups can access the egroupware suite, but with user B with the same groups only can login and only sees the top menu. Also when setting up a mail client, I can setup Thunderbird for user A but not for user B.
please point me in the right direction.
Thanks
api/src/Egw.php (138)
Database error
Connection with ADOdb::PConnect(localhost:3306, egroupware, $Password, egroupware) failed. Maybe you not created a database for EGroupware yet. (999)
Run setup to install or configure EGroupware.
