Edit portal start site appearance on slave domain
Hello
I am logged in as the administrator user on slave domain. On the portal start site there is no similar button on the right bottom corner to edit the portal appearance as on master domain. Otherwise it seems the portal works as intended. How could I fix this?
Hi, did you find out how to edit the portal on a Replica Directory Node (formerly Domain Controller Slave)? I have the same problem.
Edit: Reading the manual helps (different kind of portals).
