DVD ROM is missing
Hello, everybody,
I installed the UCS server with the DVD drive. In /etc/fstab a corresponding entry was created:
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
When I try to mount a CD I get the message:
root@vmhost02:/var/lib/libvirt/images# mount /media/cdrom0/
mount: no medium found on /dev/sr0
Okay, I thought the drive was broken. Now I tried it on another UCS server. There it is exactly the same.
How can I find out if the DVD drive is present and which device name?
best regards
sven
