In case login calls to portal lasts for too long (more than couple of seconds), there are few possible things to check:
- User tries to login is member of many groups (by many, we assume couple of dozens). If this is the case, please consider different layout, since each membership check takes some small amount of time but in total this can stack up for large number of group memberships.
