Domain locked out users
Is there a way to unlock users using univention?
Hi
I have not done this before but I would look at user account
grafik
an when that is not possible here then I would try the Windows RSAT tools
grafik
rg
Christian
It works in the RSAT tool although ive had some issues where a correct login does not always reset the bad password count back to 0
I was wondering if there is a way to do it in univention. I dont see any settings for bad password count or lockout threshold or anything
What I’ve found is that in samba the reset count is 30min per default
rg
Christian
You might use the cmd line tool pdbedit as root user
rg
Christian
