Docker installation does not work anymore
My app used to work until I tried to install it again on a fresh virtual machine to check something out. I’ve updated my 4.2 based machine to the latest patch level, no more updates available via apt.
This is what is at the end of the installation process from test app center:
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 26univention-nagios-common.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 30univention-appcenter.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 30univention-nagios-client.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 33univention-portal.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 34univention-management-console-server.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-appcenter-docker.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-appcenter.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-diagnostic.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-ipchange.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-join.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-lib.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-mrtg.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-quota.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-reboot.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-services.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-setup.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-sysinfo.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-top.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-ucr.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-udm.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-management-console-module-updater.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 35univention-server-overview.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 36univention-management-console-module-apps.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 40univention-virtual-machine-manager-schema.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 81univention-nfs-server.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 90univention-bind-post.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 91univention-saml.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 92univention-management-console-web-server.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:42 [    INFO]: Running 98univention-pkgdb-tools.inst skipped (already executed)
  4474 actions.install                  18-05-15 14:43:43 [   DEBUG]: /usr/sbin/univention-run-join-scripts returned with 0
  4474 utils                            18-05-15 14:43:43 [   DEBUG]: send_information: action=install app=kitoma value=None status=200
  4474 utils                            18-05-15 14:43:43 [   DEBUG]: tracking information: {'status': 200, 'uuid': 'ea3e4405-202f-4a27-8772-620d8896617f', 'app': u'kitoma', 'version': u'50', 'role': 'domaincontroller_master', 'action': 'install', 'system-uuid': '113c24b4-ebba-4ef9-9334-dbafa3939990'}
  4474 actions.install                  18-05-15 14:43:43 [    INFO]: File: /usr/share/univention-management-console/modules/apps.xml
  4474 actions.install                  18-05-15 14:43:44 [    INFO]: File: /usr/share/univention-management-console/i18n/de/apps.mo
  4474 actions.install                  18-05-15 14:43:45 [    INFO]: File: /etc/apt/apt.conf.d/55user_agent
  4474 actions.upgrade-search           18-05-15 14:43:45 [   DEBUG]: Calling upgrade-search
  4474 actions.upgrade-search.progress  18-05-15 14:43:45 [   DEBUG]: 0
  4474 actions.upgrade-search           18-05-15 14:43:45 [   DEBUG]: Checking kitoma=50
  4474 actions.upgrade-search           18-05-15 14:43:45 [    INFO]: Executing interface update_available for kitoma
  4474 actions.upgrade-search           18-05-15 14:43:46 [    INFO]: kitoma=50: Update available: packages
  4474 actions.upgrade-search.progress  18-05-15 14:43:46 [   DEBUG]: 100
  4474 actions.install.progress         18-05-15 14:43:46 [   DEBUG]: 100
I have no idea what happend. There is no error message (that I can find). Also the docker container are only available in the docker.io hub with version 4.2-2 and before. 4.3-0 as stated in the test app center is not found. Neither is my former 4.2-3 or 4.2-4.
Hope anyone has a hint for me.
The log indeed shows that the App was installed successfully. Can you explain what you mean by “does not work”? Does the container run after the installation?
docker ps -a
univention-app shell kitoma
The new 4.3-0 image is docker.software-univention.de/ucs-appbox-amd64:4.3-0. It exists and should work, it is just not yet on docker.io. We have our own registry for the Appbox image. Note that it is based on UCS 4.3 (Debian stretch).
I used the url given as example in the test app center. My test machine is 4.2 maybe thats the problem.
The container is running but is empty, none of the deb-packages are installed.
Mastodon
