Docker Install - Volumes to bind?
Hello everyone !
I really love your product. I’ve never seen anything like it. However, I cannot find anywhere what are the path to mount in order to save data on the host.
Could you please indicate me which path to bind ?
Thanks a lot !
Luca
That’s a doog idea. PLease let me also know how to mount other hdd volumes to ucs for sharing big data especially.
kindly
Hey there,
actually I am planning a scenario, having a docker based UCS running in a hetzner cloud environment. I’d like to know if it is possible to run even open-xchange in such a container. But I think that is not possible: [Q&A: Can I Upgrade UCS or Apps From Within the Docker Container?
I’d think it depends on what you are going to do with the docker container. I would say having at least
/etc/
/var/
/usr/
/lib/
as persisten volumes would be a good idea.
Cheers
Sebastian
In the end, what I did was to:
  1. Start the container, with VOLUME_DATA mounted inside of it at /VOLUME_DATA. docker-compose up -d
  2. Log in the container : docker exec -it ucs_container_name bash
  3. Copy root ( / ) to /DATA : rsync -av --progress --exclude run --exclude data --exclude boot --exclude --exclude dev --exclude proc / /VOLUME_DATA
  4. Stop the container : docker-compose down
  5. Remove the commented lines in the docker-compose at the volumes section
  6. Re-start the container docker-compose up -d
Your data will be saved between up and downs.
version: '3'
services:
  ucs:
    image: univention/ucs-generic-amd64
    restart: always
    hostname: subdomain
    ports:
      - 127.0.0.1:50000:443
    environment:
      - domainname=subdomain.yourdomain.com
      #- rootpwd=hereisarootpw
      - container=docker
    volumes:
      - /sys/fs/cgroup:/sys/fs/cgroup:ro
      #- ./VOLUME_DATA/etc:/etc
      #- ./VOLUME_DATA/root:/root
      #- ./VOLUME_DATA/var:/var
      #- ./VOLUME_DATA/home:/home
      #- ./VOLUME_DATA/lib:/lib
      #- ./VOLUME_DATA/lib64:/lib64
      #- ./VOLUME_DATA/sbin:/sbin
      #- ./VOLUME_DATA/usr:/usr
      #- ./VOLUME_DATA/opt:/opt
      #- ./VOLUME_DATA/CUSTOM:/CUSTOM
    tmpfs:
      - /run
      - /run/lock
    cap_add:
      - SYS_ADMIN
This looks nice indeed. Have you tried to install an app via appcenter from within the docker environment?
Yes it works, you can run apps without problems.
You only won’t be able to run apps that are docker-based, since docker-in-docker is not supported in this case.
Did anybody manage to set persistent volumes up this way recently?
I somehow did not manage to do so. That’s why I am wondering whether it is still possible.
Greetings
Gerrit
Mastodon
