W: Failure while configuring required packages.
W: See /var/tmp/docker-baseimage.osA5Cxhh84/rootfs/debootstrap/debootstrap.log for details (possibly the package package is at fault)
Removing temporary /var/tmp/docker-baseimage.osA5Cxhh84
Hi, just a quick heads up: the buildscripts in univention-docker-dev should create common-docker files dynamically. For UCS 4.2 we need to adjust a script that is run by these dockerfiles (and that is not done yet) - we have this as an open issue and I would ask for a little patience.
