we are running an UCS Server on 5.0.10. Update to 5.2 would be great and therefore we uninstalled all nomore used software like Kopano, Z-Push, Nextcloud etc. The only thing this server should do is to be an AD comptible Domain-Controller and Filseserver.
For now the update to 5.2 is not working, because of a strange missing of a SimpleSamlPHP certificate. Error in Diagnose: Zertifikat https://ucs-sso.blablabla.local/simplesamlphp/saml2/idp/certificate konnte nicht geladen werden: Unable to load certificate.Zertifikat https://192.168.xxx.xxx/simplesamlphp/saml2/idp/certificate konnte nicht geladen werden: Unable to load certificate. Führen Sie das Join-Skript 92univention-management-console-web-server via [Modul "Domänenbeitritt"](javascript:void(0)) oder univention-run-join-scripts --force --run-scripts 92univention-management-console-web-server auf der Befehlszeile as Benutzer *root* aus.
This error is there for ages (the machine is 8 years old now), but as everything worked great, i did not care. When i try to install KeyCloak it is ending up in a mess and the portal website will not be displayed due certificate errors in Apache.
As i read somewhere in this Forum, Keycloak is not needed to run the AD Domain Controller. So may i just uninstall SimpleSamlPHP? And how is this done, because it’s not visible in the App Center and it is also marked as not installed in Paket-Verwaltung.
So if it isn’t installed, why does is it disturbing the upgrade?
Thank you. I will try again next weekend.
But i like to know, if KeyCloak ist not needed for a simple domain controller and fileserver, how can i uninstall the simpleSAML and ucs-sso stuff?
If you dont want to use SingleSignOn on your environment, you will need Keycloak. But if you won’t use any SingleSignOn, you just have to complete the migration part for keycloak, to delete old and not necassary SimpleSamlPHP stuff.
This is the part from the article, you will need: 1. Complete the Keycloak Migration
