as subject says, I am running into problem when I want to resolve download.microsoft.com
Output (on Primary Domaincontroller, which is also responsable for DNS) >>
dig download.microsoft.com
; <<>> DiG 9.10.3-P4-Univention <<>> download.microsoft.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 64680
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 13, ADDITIONAL: 27
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;download.microsoft.com. IN A
;; ANSWER SECTION:
download.microsoft.com. 1378 IN CNAME 2-01-4ca6-0004.cdx.cedexis.net.
2-01-4ca6-0004.cdx.cedexis.net. 1378 IN A 127.0.0.1
;; AUTHORITY SECTION:
. 15263 IN NS m.root-servers.net.
. 15263 IN NS e.root-servers.net.
. 15263 IN NS d.root-servers.net.
. 15263 IN NS f.root-servers.net.
. 15263 IN NS h.root-servers.net.
. 15263 IN NS l.root-servers.net.
. 15263 IN NS c.root-servers.net.
. 15263 IN NS a.root-servers.net.
. 15263 IN NS j.root-servers.net.
. 15263 IN NS g.root-servers.net.
. 15263 IN NS k.root-servers.net.
. 15263 IN NS b.root-servers.net.
. 15263 IN NS i.root-servers.net.
;; ADDITIONAL SECTION:
a.root-servers.net. 480015 IN A 198.41.0.4
a.root-servers.net. 481121 IN AAAA 2001:503:ba3e::2:30
b.root-servers.net. 518488 IN A 199.9.14.201
b.root-servers.net. 8775 IN AAAA 2001:500:200::b
c.root-servers.net. 524617 IN A 192.33.4.12
c.root-servers.net. 48014 IN AAAA 2001:500:2::c
d.root-servers.net. 511508 IN A 199.7.91.13
d.root-servers.net. 524245 IN AAAA 2001:500:2d::d
e.root-servers.net. 513785 IN A 192.203.230.10
e.root-servers.net. 3015 IN AAAA 2001:500:a8::
f.root-servers.net. 518362 IN A 192.5.5.241
f.root-servers.net. 48014 IN AAAA 2001:500:2f::f
g.root-servers.net. 524617 IN A 192.112.36.4
g.root-servers.net. 3015 IN AAAA 2001:500:12::d0d
h.root-servers.net. 510641 IN A 198.97.190.53
h.root-servers.net. 48014 IN AAAA 2001:500:1::53
i.root-servers.net. 524617 IN A 192.36.148.17
i.root-servers.net. 48014 IN AAAA 2001:7fe::53
j.root-servers.net. 482835 IN A 192.58.128.30
j.root-servers.net. 48014 IN AAAA 2001:503:c27::2:30
k.root-servers.net. 524617 IN A 193.0.14.129
k.root-servers.net. 48014 IN AAAA 2001:7fd::1
l.root-servers.net. 523920 IN A 199.7.83.42
l.root-servers.net. 48014 IN AAAA 2001:500:9f::42
m.root-servers.net. 524617 IN A 202.12.27.33
m.root-servers.net. 48014 IN AAAA 2001:dc3::35
;; Query time: 0 msec
;; SERVER: 172.16.1.1#53(172.16.1.1)
;; WHEN: Tue Sep 29 09:47:30 CEST 2020
;; MSG SIZE rcvd: 891
host download.microsoft.com
download.microsoft.com is an alias for 2-01-4ca6-0004.cdx.cedexis.net.
2-01-4ca6-0004.cdx.cedexis.net has address 127.0.0.1
2-01-4ca6-0004.cdx.cedexis.net has IPv6 address ::1
2-01-4ca6-0004.cdx.cedexis.net is an alias for main.dl.ms.akadns.net.
main.dl.ms.akadns.net is an alias for download.microsoft.com.edgekey.net.
download.microsoft.com.edgekey.net is an alias for e3673.dscg.akamaiedge.net.
DNS Backend is Samba4 and when I resolve that name explicitely with defined DNS Forwarders it is working as expected.
Yes, all servers and clients behave the same way.
The output of hosts command is:
Using domain server:
Address: 172.16.1.1#53
Aliases:
Address: 172.16.1.4#53
Aliases:
; BIND data file for local loopback interface
$TTL 604800
@ IN SOA localhost. root.localhost. (
2 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
604800 ) ; Negative Cache TTL
@ IN NS localhost.
@ IN A 127.0.0.1
@ IN AAAA ::1
# add local zones here
# add local zones, which have to be declared before the Samba 4 DLZ, here
// Do any local configuration here
// Consider adding the 1918 zones here, if they are not used in your
// organization
//include "/etc/bind/zones.rfc1918";
After a while of running bind9 it throws following errors:
Sep 29 13:30:25 srv-00-01 named[22119]: DNS format error from 46.182.19.48#53 resolving _msdcs.OURDOMAIN.de/NS for client 172.16.1.4#44204: Name OURDOMAIN.de (SOA) not subdomain of zone _msdcs.OURDOMAIN.de -- invalid response
I am unsure if this is related. You might have some very unusual misconfiguration in your DNS settings. It should never ask an external DNS server for _msdcs records of your domain! And the external server should never reply! I have no clue what it could be currently. I guess it is not only UCS related.
Do ucr commit /etc/bind/* ; systemctl restart bind9.
Then set the backend to samba4 and run /usr/share/univention-samba4/scripts/check_essential_samba4_dns_records.sh
Any errors there?
No errors and you may be correct with the misconfiguration. _msdcs resolved to one of our public ip’s. After changing that it now seems to work correctly
What I am just wondering is, that the DomainControllers entry for _msdcs (set as NS entry) now vanished (because of the switching between ldap/samba4?). This entry was not set by me, so it may be a default entry. What is that NS record for?
And after a while of correctly resolving this entry, it once again is broken. I did not change anything in the meantime.
After a little digging I found out that another domain download.windowsupdate.com does have the same weird resolving.
