Hi Team,
Greetings!.
I am trying to enable https on my Azure UCS VM and I am using Let’s Encrypt UCS application for the same. But even though I am providing the DNS name instead of IP address I am still getting an error as Error creating new order :: Issuance for IP addresses not supported when I add my domain in Let’s Encrypt app settings. Can anyone please help me with this. Any help is really appreciated. Thank you.!
I just looked in to the logs and here is the content.
Create letsencrypt/status
Fr 29. Mär 12:39:30 CET 2019
Refreshing certificate for following domains:
https://lmz-dev.northeurope.cloudapp.azure.com/
Parsing account key...
Parsing CSR...
File "/usr/share/univention-letsencrypt/acme_tiny.py", line 197, in <module>
main(sys.argv[1:])
File "/usr/share/univention-letsencrypt/acme_tiny.py", line 193, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File "/usr/share/univention-letsencrypt/acme_tiny.py", line 90, in get_crt
out = _cmd(["openssl", "req", "-in", csr, "-noout", "-text"], err_msg="Error loading {0}".format(csr))
File "/usr/share/univention-letsencrypt/acme_tiny.py", line 28, in _cmd
raise IOError("{0}\n{1}".format(err_msg, err))
IOError: Error loading /etc/univention/letsencrypt/domain.csr
unable to load X509 request
139707857842240:error:0906D06C:PEM routines:PEM_read_bio:no start line:../crypto/pem/pem_lib.c:686:Expecting: CERTIFICATE REQUEST
Setting letsencrypt/status
Setting letsencrypt/services/apache2
File: /etc/apache2/sites-available/univention-letsencrypt.conf
Fr 29. Mär 12:44:20 CET 2019
Parsing CSR...
main(sys.argv[1:])
140626029727808:error:0906D06C:PEM routines:PEM_read_bio:no start line:../crypto/pem/pem_lib.c:686:Expecting: CERTIFICATE REQUEST
Kindest Regards
Sibeesh Venu
