Deny Access to UCS Portal externally not working
Hi All,
First post so apologies if this has already been covered, but I followed the article here but this no longer works.
When restarting apache2 you get the following error message in via journalctl -xe
Feb 19 10:37:57 ucs-6208 apachectl[10201]: [Tue Feb 19 10:37:57.317671 2019] [so:warn] [pid 10204] AH01574: module au
Feb 19 10:37:57 ucs-6208 apachectl[10201]: AH00526: Syntax error on line 2 of /etc/apache2/conf-enabled/umc-access.co
Feb 19 10:37:57 ucs-6208 apachectl[10201]: Unknown Authz provider: IP
Feb 19 10:37:57 ucs-6208 apachectl[10201]: Action ‘graceful’ failed.
Feb 19 10:37:57 ucs-6208 apachectl[10201]: The Apache error log may have more information.
Feb 19 10:37:57 ucs-6208 systemd[1]: apache2.service: Control process exited, code=exited status=1
Feb 19 10:37:57 ucs-6208 systemd[1]: Reload failed for The Apache HTTP Server.
I’ve had a quick dig around and modules seem to be called to load via apache2.conf
Cheers
James
Post the full content of the file you’ve created, please.
