Cyrus/imap No or ambigous results found: 0
in der mail.warn und mail.err bekomme ich einen Fehlerhinweis:
cyrus/imap No or ambigous results found: 0
Dieser Eintrag wiederholt sich immer wieder.
Woher kommt das und was habe ich falsch konfiguriert?
Gruß Jochen
looks like this is a default string from Cyrus and I would say it can be ignored.
BTW: Cyrus will be dicontinued with next releases of UCS. You should consider a different solution.
/KNEBB
thank you for your reply.
So, what should i use instead of cyrus? Is there a tool to switch to another program?
Kind regards
Jochen
https://help.univention.com/t/migration-of-cyrus-2-4-to-dovecot/6679
