for servers where there is no Samba 4 installation I consider this to be a false positive. See this bug for details.
For servers that do have a Samba 4 installation: please post the output of the following commands run on the server where the system diagnosis shows the error:
I am also having problem running this joinscript on the same machine.
Thu Feb 15 11:24:29 CET 2018
2018-02-15 11:24:29.118619743+01:00 (in joinscript_init)
Waiting for RID Pool replication: …
Error no rIDSetReferences replicated for ucskvm1
EXITCODE=1
Thu Feb 15 11:27:58 CET 2018
I have this error on more than one server, currently there are two servers, originally there were four servers of which 3 had a Samba4 installation with this error.
Server 1 is ucstest
Server 2 is ucskvm1
Well you said “for servers where there is no Samba 4 installation I consider this to be a false positive. See this bug1 for details”. Ucstest has no Samba4 so we can leave server1 for the time beeing.
The other server is ucskvm1 (server 2) where there is a Samba4 installation. This is the server that is giving me a lot of problem.
root@ucskvm1:/var/log/univention# ucr get samba/interfaces/bindonly
yes
lo <interfaces/primary>
I also get Critical: Check local AD database for error
samba-tool dbcheck returned a problem with the local AD database.
STDOUT: Checking 270 objects
No RID Set found for this server: CN=UCSKVM1,OU=Domain Controllers,DC=sunhut,DC=local, and we are not the RID Master (so can not self-allocate)
Please use --fix to fix these errors Checked 270 objects (1 errors)
You can run samba-tool dbcheck --fix to fix the issue.
I sugget you try to re-join the server. Re-joining won’t remove any of your data, but it may actually fix issues such as the one you’re observing. Just run univeniton-join on ucskvm1.
You said kinit for ucskvm1 was OK but I still have the diagnostic error “Critical: Check kerberos authenticated DNS update”, is that a false positiv despite the server having a Samba4 installation?
The join is still stuck on 98univention-samba4-dns.inst with this error in join.log.
Fri Feb 16 14:47:48 CET 2018
2018-02-16 14:47:48.483258751+01:00 (in joinscript_init)
EXITCODE=1
Fri Feb 16 14:51:09 CET 2018
