Create CAA record
Is there any possibility to create a CAA record in UCS DNS (Bind with samba4 backend). I need to to get Labca (Letsencrypt CA for private network certificate distribution) working.
fhz
I came up with the idea of using nsupdate:
adding a A record with nsupdate is no problem, adding CAA ist not working (Update failed: SERVFAIL)
This is the command used: update add mydomain.local 86400 CAA 0 issue “mydomain.local”
Any hints?
Mastodon
