CPU and RAM consumption are constantly going up
Hi there,
since an UCS update, probably back in October '25, the CPU and RAM consumtion is constantly going up.
With a reboot it seem to be normal for a while but then going up again.
The UCS server is running on proxmox VE 9.1.2 with 2 CPU and 8 GB RAM.
Anyone else having the same problem?
I’m running the latest UCS 5.2 version.
I had such consumption after removing a UCS Backup/Slave Server from Domain that also was Samba 4 Server. The Problem ist the Samba replication - i had to remove the host also from Samba Domain
Did you ever had a second member server in your domain ?
Rg
Christian
I have a backup DC in my domain, running on a proxmox VE too.
