Corrupt/broken OwnCloud container
Hey everyone,
I am new to the forum, so bare with me.
Problem: after recent univention-upgrade, OwnCloud stopped working on my private/test server.
Front-end: Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Back-end:
Latest version: 10.3.2
Docker container: running.
Troubleshooting (so far):
univention-app register OK
univention-app remove FAILS w/can’t backup data
univention-app install FAILS w/“it’s already installed”
univention-app upgrade FAILS w/same error as before
Notes: there’s something bizarre/consistent about each process. It tries to backup the previous container data, but fails.
Image upgrade script (pre) failed
Storing data for 4.3/owncloud=10.2.1-1 failed
Could not backup container!
Aborting...
Some networks were defined but are not used by any service: appcenter_net
Starting redis    ...
Starting owncloud ...
Since this is a test environment, I would be okay to simply purge the container, unregister the app and reinstall, but if there’s more appropriate fix, I’ll take that instead.
I am sure I’ll be running into this in my production environments and it would be nice to know the proper way to handle it.
Bumping for good measures…
Anyone, any ideas?
I have been running UCS and ownCloud for years. I built 2 VMs as primary and backup domain controllers installed release version is 5.0-1 errata182. I attempted to install ownCloud on the primary and ownCloud got stuck attempting to connect with LDAP. I installed ownCloud using the command line univention-app install owncloud and owncloud started but had an invalid enterprise license key. when I try to log in I get this message at the username and password prompt: Invalid license key!
Please contact your administrator or sales@owncloud.com for a new license key.
I ended up starting with version 4 and upgrading to version 5. When I installed version 4 i also installed ownCloud once the primary and backup domain servers were online I went through the upgrade process to version 5 and everything is working as advertised.
