Note: Cool Solutions are articles documenting additional functionality based on Univention products. Packages provided by a Cool Solutions Repository are built by Univention professional service, but will not necessarily be maintained. Not all the shown steps in the article are covered by Univention Support. For questions about your support coverage, contact your contact person at Univention before you want to implement one of the shown steps.
The package univention-ldap-restore offers a possibility to restore deleted objects, attributes and group memberships from LDAP backup files. UCS writes a daily LDAP backup to /var/univention-backup by default.
You can create an on-the-fly-backup with: slapcat | gzip > backup.ldif.gz.
Limitations
If the restored attributes are unique ones (like uid, uidNumber, sambaSID, entryUUID) and found on another object, then the object can’t be restored from the backup (see table below).
Installation
After enabling the Cool Solutions Repository (https://help.univention.com/t/cool-solutions-articles-and-repository/11517)
you can install the package with the following command:
univention-install univention-ldap-restore
Usage
After the package is installed you can restore a given DN from a backup file.
The usage is as follows:
univention-restore-ldap-object-from-backup --dn [DN] -b [backup file]
The script provides the following options:
| Option | Effect |
| -h, --help | show help message and exit |
| -b BACKUP_FILE, --backup-file BACKUP_FILE | gz ldif backup file (/var/univention-backup/ldap-backup_20180604.ldif.gz) |
| -d DN, --dn DN | LDAP DN to look for in backup |
| -l, --list-dns | list all LDAP DNs from backup and exit |
| -v, --verbose | verbose output |
| -m, --restore-membership | restore uniqueMember of DN |
| -r, --delete-missing | delete LDAP object if object is not in backup |
| -n, --dry-run | dry run, make no changes in LDAP |
The script behaves as follows:
| Prerequisite | Behaviour |
| DN was not found in LDAP, found in backup | object is restored from backup |
| DN was found in LDAP, found in backup | the object’s attributes are restored (overwritten) from backup |
uid, uidNumber, sambaSID, entryUUID of specified DN was found in other object than the specified DN in LDAP |
no changes are made |
| DN was found in LDAP, not found in backup, --delete-missing is set | object is deleted from LDAP |
Usage examples
Restore deleted user object or overwrite attributes of existing user object with uid:
example-user1 using backup file from 2022-10-24:
univention-restore-ldap-object-from-backup -d uid=example-user1,cn=users,dc=ucs,dc=demo \
-b /var/univention-backup/ldap-backup_20221024.ldif.gz
example-user1 with group memberships using backup file from 2022-10-24:
univention-restore-ldap-object-from-backup -m -d uid=example-user1,cn=users,dc=ucs,dc=demo \
Delete existing user object with uid example-user1 because it’s not present in backup:
univention-restore-ldap-object-from-backup -r -d uid=example-user1,cn=users,dc=ucs,dc=demo \
