Note: Cool Solutions are articles documenting additional functionality based on Univention products. Not all of the shown steps in the article are covered by Univention Support. For questions about your support coverage contact your contact person at Univention before you want to implement one of the shown steps.
This article describes how to configure the Network File System (NFS) in Version 4 for Univention Corporate Clients (UCC) and Univention Corporate Servers (UCS). Since UCS 3.2 NFSv4 is activated by default.
NFS on UCS
Shares on UCS
For bigger environments, it is recommended to set up a separate file server (e.g. DC Slave). On this server, shares can be created as described in the UCS documentation.
Configuration in the Univention Management Console
Beside several different options in the tab ‘NFS’ which are described in the UCS documentation, it is possible to set the following Univention Configuration Registry variables:
nfs/autostart- This variable configures the start mode of the NFS service. If set tonoordisabled, the service cannot be started. If the variable is set tomanually, the service isn’t started during system boot, but can be enabled manually at a later point. -
nfs/common/gssd- This variable defines if the gssd daemon should be started. Evaluated values areyes,noor (default=yes). -
nfs/common/idmapd- This variable defines if the idmap daemon should be started. Evaluated values areyes,noor (default=yes). -
nfs/create/homesharepath- If this option is activated, the home directory configured for a user in the attributes Home share and Home share path is automatically created through a Univention Directory Listener module. -
nfs/nfsd/nfs4- This option activates the NFSv4 support of the NFS server. In addition the IDMAPD process must be configured usually. -
nfs/ports- If this variable is set tostatic, fixed ports are used for the NFS services: 32767 for RPC mounts, 32765/32766 for statd and 32769 for the quota service. Otherwise the ports are assigned dynamically. -
ucc/pxe/nfsroot- Sets the PXE rollout server in the domain.
NFS for UCC
Prerequisite:
Install the needed package:
apt-get install nfs-common
Besides that you need a directory the NFS directory will be mounted to.
mkdir <PATH TO MOUNT POINT>
Temporary mount
Verify following setting in the following file on your UCS Server: /etc/default/nfs-kernel-server:
NEED_SVCGSSD=no
To temporary mount a NFSv4 share, use following command:
mount -t nfs4 <NFS SERVER>:<PATH TO SHARE> <PATH TO LOCAL MOUNT POINT>
Static mount
To add the share permanently, it is possible to mount the share statically during the system startup. Therefore, the following line has to be added to the /etc/fstab file (USE TABS BETWEEN THE VALUES):
<NFS SERVER>:<PATH TO SHARE> <PATH TO LOCAL MOUNT POINT> nfs4 auto 0 0
Auto mount
It is possible to only mount the share when accessed and unmount it after a period of inactivity.
This conserves bandwidth and increases the overall performance.
For this, it is necessary to install autofs:
apt-get install autofs
You also have to create the folder /etc/auto.master.d if it doesn’t exist yet:
mkdir -p -m755 /etc/auto.master.d/
Afterwards, add the following line to the bottom of the file /etc/auto.master:
/- /etc/auto.master.d/auto.<NAME OF SHARE> --timeout=60 --ghost
Now, create the file /etc/auto.master.d/auto.NAME OF SHARE and insert the following line (USE TABS BETWEEN THE VALUES):
<PATH TO LOCAL MOUNT POINT> -fstype=nfs4 <NFS SERVER>:<PATH TO SHARE>
Verify following settings in /etc/default/nfs-common:
NEED_IDMAPD=yes
NEED_GSSD=no # Default
Reload autofs:
service autofs restart
Test, if it worked:
ls <PATH TO LOCAL MOUNT POINT>
References
- Release Notes Univention Corporate Server 3.2: http://docs.univention.de/release-notes-3.2-en.html#idp3973216
- SettingUpNFSHowTo - Community Help Wiki
- Autofs - Community Help Wiki
