Cool Solution - Installing UCS in Microsoft Hyper-V
Note: Cool Solutions are articles documenting additional functionality based on Univention products. Not all of the shown steps in the article are covered by Univention Support. For questions about your support coverage contact your contact person at Univention before you want to implement one of the shown steps.
This article is giving an overview over the installation of UCS 4.2 and 4.3 inside Microsoft Hyper-V.
The process of the installation described in the following article is tested with Windows Server 2016 with Hyper-V. The instructions described here might differ for older version of Windows Server/Hyper-V.
Creation of Virtual Machine
For the creation of the virtual machine, you first have to download the UCS ISO file provided on our Homepage.
After your download is finished, you can create the machine via the Menu Actions → New → Virtual Machine inside the Hyper-V Manager.
Here, you have to make sure to select Generation 1 as virtual machine generation in the Specify Generation tab, and choose the UCS iso-File as installation image file. Everything else can be configured to your desires.
Installation of UCS
During the installation there are no special requirements. However, to ensure a proper functioning, you should install the newest patchlevel and errata updates for UCS 4.
You can study the UCS Quickstart guide for further help during the installation. Please also consider reading the known issues stated on this page.
Further links
