Introduction
The package univention-homedir-autocreate creates a users home directory automatically without the need of a login from the user. However, this packages does not create home directories on a NFS share. This is done by the listener module nfs-homes which comes with the package univention-nfs.
Installation
After enabling the Cool Solutions Repository you can install the package with the following command:
univention-install univention-homedir-autocreate
Usage
By setting the Unix Home Directory in the Account tab of the UMC, the listener gets triggered and creates the respective directory. Additional folders can be created using univention-skel upon the first login of the user.
