Connection refused
since some days the sending of emails doesnt work any longer. The mail exchance stuck at the Connection to two porviders (strato, gmx). Please see the mail.log:
Aug 30 16:13:58 mail postfix/smtpd[23364]: connect from localhost[127.0.0.1]
Aug 30 16:13:58 mail postfix/smtpd[23364]: B4758102756: client=localhost[127.0.0.1], orig_queue_id=3D394FFE00, orig_client=localhost[127.0.0.1]
Aug 30 16:13:58 mail postfix/cleanup[23360]: B4758102756: message-id=<HnUNOWerQNCDRN8m3zXIdA@ismtpd0009p1iad2.sendgrid.net>
Aug 30 16:13:58 mail postfix/qmgr[1607]: B4758102756: from=<bounces+1434781-11c0-meineMail2=gmx.net@mailx1.ebay.com>, size=73883, nrcpt=1 (queue active)
Aug 30 16:13:58 mail postfix/smtpd[23364]: disconnect from localhost[127.0.0.1] ehlo=1 xforward=1 mail=1 rcpt=1 data=1 quit=1 commands=6
Aug 30 16:13:58 mail amavis[11984]: (11984-02) Passed CLEAN {RelayedInternal}, LOCAL [127.0.0.1]:56184 [66.135.198.142] <bounces+1434781-11c0-meineMail2=gmx.net@mailx1.ebay.com> -> <meineMail2@gmx.net>, Queue-ID: 3D394FFE00, Message-ID: <HnUNOWerQNCDRN8m3zXIdA@ismtpd0009p1iad2.sendgrid.net>, mail_id: CukqUz2OFxSD, Hits: -13.825, size: 72944, queued_as: B4758102756, 1396 ms
Aug 30 16:13:58 mail postfix/smtp[23361]: 3D394FFE00: to=<meineMail2@gmx.net>, relay=127.0.0.1[127.0.0.1]:10024, delay=1.7, delays=0.29/0.05/0.01/1.4, dsn=2.0.0, status=sent (250 2.0.0 from MTA(smtp:[127.0.0.1]:10025): 250 2.0.0 Ok: queued as B4758102756)
Aug 30 16:13:58 mail postfix/qmgr[1607]: 3D394FFE00: removed
Aug 30 16:13:59 mail postfix/lmtp[23365]: B4758102756: to=<meineMail2@gmx.net>, relay=127.0.0.1[127.0.0.1]:2003, delay=1, delays=0.18/0.02/0.07/0.76, dsn=2.1.5, status=sent (250 2.1.5 meineMail2@gmx.net Ok)
Aug 30 16:13:59 mail postfix/qmgr[1607]: B4758102756: removed
Aug 30 16:24:28 mail postfix/qmgr[1607]: 35AA2FFDFF: from=<info@meineMail1.de>, size=4655, nrcpt=1 (queue active)
Aug 30 16:24:28 mail postfix/qmgr[1607]: 72930FFB9C: from=<info@meineMail1.de>, size=6000, nrcpt=1 (queue active)
Aug 30 16:24:28 mail postfix/smtp[30315]: connect to smtp.strato.de[81.169.145.133]:25: Connection refused
Aug 30 16:24:28 mail postfix/smtp[30316]: connect to smtp.strato.de[81.169.145.133]:25: Connection refused
Aug 30 16:24:28 mail postfix/smtp[30315]: 35AA2FFDFF: to=<lutz1000@arcor.de>, relay=none, delay=330497, delays=330497/0.17/0.03/0, dsn=4.4.1, status=deferred (connect to smtp.strato.de[81.169.145.133]:25: Connection refused)
Aug 30 16:24:28 mail postfix/smtp[30316]: 72930FFB9C: to=<lutz1000@arcor.de>, relay=none, delay=338730, delays=338730/0.1/0.01/0, dsn=4.4.1, status=deferred (connect to smtp.strato.de[81.169.145.133]:25: Connection refused)
Hopefully somebody can give me a hint where I have to look for the problem. Keep in mind that the mail exchange did work the whole time without Problems and also no chances was made in the last time like updates etc. Maybe a service stucks but which one?! Also the restart of Postfix brings no success.
/var/log$ /etc/init.d/postfix stop
Stopping postfix (via systemctl): postfix.service.
/var/log$ /etc/init.d/postfix start
Starting postfix (via systemctl): postfix.service.
Gibt es niemanden der eine Idee hat, woran es hängen könnte? Danke für eine Anregung!
Der MX scheint die verbindung abzulehnen. Versuch doch mal vom UCS aus via
telnet 81.169.145.133 25
eine Verbindung zum MXer aufzubauen.
Sollte sowas wie anzeigen:
Trying 81.169.145.133…
Connected to 81.169.145.133.
Escape character is ‘^]’.
220 smtp.strato.de ESMTP RZmta (P6 -)
Grüße
pider
Hallo Pider,
erstmal danke für deinen Support! Wie kann ich von UCS die Verbindung prüfen sprich wie kann ich über UCS Telnet nutzen? Habe mich mit Putty eingelogt aber Telnet Komando gibt es keins! Habe die Verbindung von Meinem PC geprüft:
C:\Users\lutz>telnet 81.169.145.133 25
Verbindungsaufbau zu 81.169.145.133...Es konnte keine Verbindung mit dem Host hergestellt werden, auf Port 25: Verbindungsfehler
Hast du eine Idee was hier schief läuft?
Hallo dark957,
du sitzt sicherlich hinter einem Router mit Firewall. Kann es sein das der die Verbindung blockiert ?
Die Verbindung zu anderen smtp server funktioniert ?
Beste Grüße
pider
Hallo Pider,
habe gerade mal dem Mailserver vollfreigabe gegeben (expose host in AVM sprache), leider ohne Erfolg. Es gehen keine mails raus das SMTP Relay versucht einmal über strato und einmal über GMX zu versenden:
Sep 6 10:12:55 mail postfix/smtp[24999]: connect to mail.gmx.net[212.227.17.168]:25: Connection refused
Sep 6 10:08:50 mail postfix/smtp[24559]: connect to smtp.strato.de[81.169.145.133]:25: Connection refused
Was mich nur wundert beide male wird versucht über Port 25 der Host anzusprechen. Müsste es nicht bei Strato 465 und bei GMX 587 sein?
PS.: Habe gerade mal Outlook pop3 über Strato auf meinem PC eingerichtet, läuft ohne Probleme
Hallo dark957,
schalte bitte schnell den exposed host wieder ab. Damit machst du deinen Server komplett von außen erreichbar.
Es sollte normal auch über den port 25 funktionieren ich erreiche die Server beide darüber.
465 ist der ssl smtp port
587 ist ein alternativport zu 25
AVM hat eine Filteroption für Ausgehende Traffic AVM Sicherheitsfilter prüf doch mal ob diese nicht aktiviert sind und die Fritzbox somit port 25 filtert
Hallo Pider,
die Vollfreigabe hatte ich nur 5 min drin um zu prüfen, ob hier die Säge klemmt! Danke für deine Anregung bezüglich der Sicherheitseinstellungen! DAS WAR RICHTIG! Wenn man schon mal dran rum spielt! DANKE DANKE DANKE! Jetzt läufts wieder!
