I am currently trying to get an overview of NextCloud in combination with Collabora.
I have set up a server VM (4.4-4 errata499 / Member) and installed NextCloud from the App-Center.
For the Collabora installation I now have two options:
a) Installation from the UCS App-Center
b) Installation from the NextCloud App Catalog
The version in the UCS App-Center is a full version that requires a license key or if I don’t have one I get a watermark on the documents, right? That means I can not use this version for free.
Is the version from the NextCloud App Catalog free and can I use it without restrictions?
I have looked around the web for instructions. Here it is said that a document server is still needed. What exactly do I still need here?
The documents must be stored/managed somewhere. And not a classic file server, but something like EGroupware, Nextcloud, …
Of course you can integrate file servers there as well.
I also explained this in the lecture.
I have one more question. I have a separate VM for the cloud. It has NetxCloud installed from the app catalog. Does CODE integrate into NextCloud if I install it from the app catalog as well or is it independent of it?
Or do I have this integration only when I install it inside NextCloud as an app?
When I open NextCloud I find under Apps “only” Collabora Online and not CODE and if I understood it correctly “Collabora Online” is liable to pay costs.
Das wäre bei mir aber auf ein und der selben VM. Das ist das was mich verwirrt. Wenn ich es richtig verstanden habe ist doch CODE aus dem App-Katalog von UCS und “Collabora Online” aus dem App-Katalag in NextCloud doch das selbe mit dem Unterschied das CODE die Developer Version ist. Oder habe ich das falsch verstanden?
Nochmal kurz zur Umgebung. Meine Dateien (Freigaben) liegen alle auf dem Master (srv01.intern.lan). Ich habe einen UCS-Member (cloud01.intern.lan) aufgesetzt und auf diesem NextCloud installiert. Hier in Nextcloud habe ich die Freigaben vom Master eingebunden um unter anderem die LibreOffice Dokumente die auf den Freigaben liegen per Browser zu bearbeiten.
Nun muss ich auf der VM (cloud01) wirklich beides installieren:
Ja. In den App-Einstellungen mußt du die URL zu einem Collabora-Server eingeben. Probier es einfach aus. Eine Nextcloud-App ist notfalls schnell wieder deinstalliert …
