Clientserver is not visble in Dashboard
I have Installed Dashboard/database on a DC slave server. and the Dashboard client on a member server.
The server where Dashbord/Database is installed is is visible in the Dashboard while the memberserver is not.
I cannot find any documentation/manual on the implementation of the Dashboard so I need assistance
The Dashboard idea is a great addition to Univention UCS.
Is the member server joined into the UCS domain (univention-join)?
The LDAP object of the member server gets a “UniventionService=metrics-node” during the join. Please check with univention-ldapsearch cn=$NAME_OF_THE_MEMBER.
Best regards,
Felix
Yes the server is joined into the domain.
univention-ldapsearch cn=ucs-proxy.sunhut.local
extended LDIF
LDAPv3
base <dc=sunhut,dc=local> (default) with scope subtree
filter: cn=ucs-proxy.sunhut.local
requesting: ALL
search result
search: 3
result: 0 Success
numResponses: 1
I had a similar situation now, so i will continue in this old thread.
To get more info about the connection, you can look into what prometheus has to say at:
https://YOUR_SERVER/metrics-prometheus/targets
Connection error because of a certificate problem will be displayed there, for example.
