Based on this article, I cleaned up legacy entries in LDAP.
The following objects are no longer supported with UCS 5.2:
dn: cn=24x7,cn=nagios,dc=party,dc=lan
dn: cn=WorkHours,cn=nagios,dc=party,dc=lan
dn: cn=NonWorkHours,cn=nagios,dc=party,dc=lan
They must be removed before the update can be done.
But then the following appeared when I pressed remove:
bash check.sh delete_legacy_objects
Starting check.sh (Do 13. Mär 18:44:18 CET 2025):
Removing structural objects
(structuralObjectClass=univentionNagiosTimeperiodClass)
Removing auxiliary data
(objectClass=univentionVirtualMachineGroupOC)
(objectClass=univentionVirtualMachineHostOC)
The auxiliary entries were not visible in the first output. Is that normal?
Sorry for the late reply. It has worked. The normal check command give me this output:
Starting ./check.sh (Sa 10. Mai 15:08:33 CEST 2025):
Checking auth_faillog ... OK
Checking blocking_apps ... OK
Checking disk_space ... OK
Checking docker_storage_driver ... OK
Checking failed_ldif ... OK
Checking for_postgresql96 ... OK
Checking hold_packages ... OK
Checking keycloak_migration ... OK
Checking ldap_connection ... OK
Checking ldap_schema ... OK
Checking legacy_objects ... OK
Checking master_version ... OK
Checking min_version ... OK
Checking minimum_ucs_version_of_all_systems_in_domain ... OK
Checking openldap_bdb ... OK
Checking overwritten_umc_templates ... OK
Checking package_status ... OK
Checking role_package_removed ... OK
Checking selinux_deactivated ... OK
Checking slapd_on_member ... OK
Checking system_date_too_old ... OK
Checking user_country_mapping ... OK
Checking valid_machine_credentials ... OK
Checking verify_translog_schema ... OK
If i say: “./check.sh delete_legacy_objects” I get this:
Starting ./check.sh (Sa 10. Mai 15:09:34 CEST 2025):
But I assume that this is normal and okay in this case? Because every check is confirmed with “OK” at the top.
