Check_nt CPULOAD
I have the NSClient++ installed and listening on port 1248 {changed}. If I run:
./check_nt -H {Host} -v CPULOAD -l 1,90,95
I get the correct response, but adding that to UCS:
Command: check_nt
Arguments: CPULOAD!1,90,95
OR: CPULOAD!-l 1,90,95
I get:
SERVICE ALERT: {Host};CHECK_WIN_CPU;UNKNOWN;SOFT;1;missing -l parameters
I’ve tried hundreds of combinations now and I cannot get the arguments to pass.
What is the correct syntax? Yes, I read the manual. Doesn’t really help.
Everything is current with univention-upgrade. Thanks in advance.
Solved my own problem.
For anyone else experiencing this issue, check_nt only passes one argument. This means you can’t use the !. You need to send everything in '.
‘CPULOAD -l 1,80,90’
You can see what UCS will send in the Nagios Configuration --> Commands page.
Hope this helps someone.
