Always when I change the certificate in the web interface and reboot, I am stuck with a bricked system:
Unhandled Exception
“Unable to validate Signature”
See attached screenshot. I consider this a bug.
Best regards,
Michael
Unhandled Exception
Best regards,
Michael
Can you describe in detail (or point to the part of the documentation) which steps are taken to change the certificate?
Best Regards,
Dirk
Hi Dirk,
I go to “System/Certificate settings”, change the following:
CN from “Univention Corporate Server Root CA (ID=uj2OBl27)” to " Corporate Server Root CA (ID=uj2OBl27)"
Email Address from ssl@int..com to ssl@.com
Location Settings from Germany to Austria
(State and Location are detected properly to AT)
Business Unit from “Univention Corporate Server” to “IT”
Then I save and popup says its restarting services.
After that, the installation is bricked, eg. I can see the main webpage, but can not longer logon to the Admin-Page.
Service restart on the console is working.
Regards,
Michael
I am not able to reproduce this. My steps:
It might as well be related to the Browser and its certificate handling.
Best Regards,
Dirk
This interesting,
this happens with a clean UCS VMWare Image, cleanly downloaded and setup only with the gui.
So this should be reproducable with the original UCS Vmware image, though.
Best regards,
Michael
