Can someone help me Collabora Online Development Edition won't start anymore
Hello ive just notice that Collabora Online Development Edition version 24.04.8.2 do not start anymore
Im running UCS version 5.0-9 errata1166
Here is some debug ive take
root@cloud:~# docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
24e33ba4a995 docker.software-univention.de/collabora:24.04.8.2 “/bin/sh -c 'bash st…” 3 weeks ago Created objective_bhabha
d55564f33fcb docker.software-univention.de/collabora:24.04.8.2 “/bin/sh -c 'bash st…” 3 weeks ago Up 24 hours 0.0.0.0:9980->9980/tcp trusting_davinci
b4aa8dc29c61 docker.software-univention.de/nextcloud:28.0.7-0 “/bin/sh -c /usr/sbi…” 4 months ago Up 24 hours 0.0.0.0:40000->80/tcp dazzling_robinson
Is it normal that we see 2 collabora docker here ?
root@cloud:~# systemctl start docker-app-collabora.service
Job for docker-app-collabora.service failed because the control process exited with error code.
See “systemctl status docker-app-collabora.service” and “journalctl -xe” for details.
root@cloud:~# systemctl status docker-app-collabora.service
● docker-app-collabora.service - LSB: Start the Container for collabora
Loaded: loaded (/etc/init.d/docker-app-collabora; generated)
Active: failed (Result: exit-code) since Thu 2024-11-21 10:08:09 EST; 14s ago
Process: 15891 ExecStart=/etc/init.d/docker-app-collabora start (code=exited, status=1/FAILURE)
Nov 21 10:08:08 cloud systemd[1]: Starting LSB: Start the Container for collabora…
Nov 21 10:08:09 cloud docker-app-collabora[15891]: Starting collabora Container 24e33ba4a995dce6611e482227e68a1fcf4f809dc2fe4c10f7d770c9819650e7 …Error response from daemon
Nov 21 10:08:09 cloud systemd[1]: docker-app-collabora.service: Control process exited, code=exited, status=1/FAILURE
Nov 21 10:08:09 cloud systemd[1]: docker-app-collabora.service: Failed with result ‘exit-code’.
Nov 21 10:08:09 cloud systemd[1]: Failed to start LSB: Start the Container for collabora.
root@cloud:~# journalctl -xe
– The job identifier is 5026.
Nov 21 10:08:09 cloud kernel: docker0: port 3(vethee15b02) entered blocking state
Nov 21 10:08:09 cloud kernel: docker0: port 3(vethee15b02) entered disabled state
Nov 21 10:08:09 cloud kernel: device vethee15b02 entered promiscuous mode
Nov 21 10:08:09 cloud systemd-udevd[15936]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 21 10:08:09 cloud systemd-udevd[15936]: Using default interface naming scheme ‘v240’.
Nov 21 10:08:09 cloud systemd-udevd[15936]: Could not generate persistent MAC address for vethbdc2c7d: No such file or directory
Nov 21 10:08:09 cloud systemd-udevd[15937]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 21 10:08:09 cloud systemd-udevd[15937]: Using default interface naming scheme ‘v240’.
Nov 21 10:08:09 cloud systemd-udevd[15937]: Could not generate persistent MAC address for vethee15b02: No such file or directory
Nov 21 10:08:09 cloud dockerd[818]: time=“2024-11-21T10:08:09.132229986-05:00” level=warning msg="Failed to allocate and map port 9980-9980: Bind for 0.0.0.0:9980 failed: por
Nov 21 10:08:09 cloud kernel: device vethee15b02 left promiscuous mode
Nov 21 10:08:09 cloud dockerd[818]: time=“2024-11-21T10:08:09.193930524-05:00” level=error msg="24e33ba4a995dce6611e482227e68a1fcf4f809dc2fe4c10f7d770c9819650e7 cleanup: fail
Nov 21 10:08:09 cloud systemd[1]: var-lib-docker-overlay-7d7a9064f9d16335f992fb2c3cc6d2223adb4e47eabee2c4d95534d65bb11e1c-merged.mount: Succeeded.
– Subject: Unit succeeded
– Defined-By: systemd
– Support: Debian -- User Support
– The unit var-lib-docker-overlay-7d7a9064f9d16335f992fb2c3cc6d2223adb4e47eabee2c4d95534d65bb11e1c-merged.mount has successfully entered the ‘dead’ state.
Nov 21 10:08:09 cloud dockerd[818]: time=“2024-11-21T10:08:09.207578437-05:00” level=error msg="Handler for POST /v1.41/containers/24e33ba4a995dce6611e482227e68a1fcf4f809dc2f
– Subject: Unit process exited
– An ExecStart= process belonging to unit docker-app-collabora.service has exited.
– The process’ exit code is ‘exited’ and its exit status is 1.
– Subject: Unit failed
– The unit docker-app-collabora.service has entered the ‘failed’ state with result ‘exit-code’.
– Subject: A start job for unit docker-app-collabora.service has failed
– A start job for unit docker-app-collabora.service has finished with a failure.
– The job identifier is 5026 and the job result is failed.
Nov 21 10:08:46 cloud CRON[15665]: pam_unix(cron:session): session closed for user root
lines 1144-1189/1189 (END)
Can someone help me with that please
Thanks !
Well i fix my problem
Ive remove the 2 dockers
root@cloud:~# sudo docker rm 24e33ba4a995 -f
24e33ba4a995
root@cloud:~# sudo docker rm d55564f33fcb -f
d55564f33fcb
b4aa8dc29c61 docker.software-univention.de/nextcloud:28.0.7-0 “/bin/sh -c /usr/sbi…” 4 months ago Up 25 hours 0.0.0.0:40000->80/tcp dazzling_robinson
I then install Collabora Online Development Edition 24.04.9.2 in UCS web interface and it fixed everything
Active: active (exited) since Thu 2024-11-21 10:27:28 EST; 58s ago
Tasks: 0 (limit: 4915)
Memory: 0B
CGroup: /system.slice/docker-app-collabora.service
Nov 21 10:27:26 cloud systemd[1]: Starting LSB: Start the Container for collabora…
Nov 21 10:27:28 cloud docker-app-collabora[20950]: Starting collabora Container 157352df0731d45df4fabfa1f7d572c51cb0c3a12b4995e8ee543c5b8059f116 …
Nov 21 10:27:28 cloud systemd[1]: Started LSB: Start the Container for collabora.
Now i have only 1 docker for Collabora Online Development Edition and everything is working fine
157352df0731 docker.software-univention.de/collabora:24.04.9.2 “/bin/sh -c 'bash st…” About a minute ago Up 45 seconds 0.0.0.0:9980->9980/tcp admiring_herschel
