Hello all,
I have strange issue. I have exists Master UCS in AWS. I joined Slave and another 2xBackups in AWS to my Master. All was good. In house I have Proxmox server with VM’s. One of this is UCS version 4.0-4 like rest. I’m trying to join Master but I have problems like:
56741937 /etc/ldap/slapd.conf: line 50: <suffix> invalid DN 21 (Invalid syntax) slapschema: bad configuration file!.
After installation I have problem in slapd.conf. It is the same like rest slapd.conf’s on Backups and Slaves in AWS.
I tired joined by Wizard and by command line. Always I have issue like:
Check DC Master: done
Stop LDAP Server: done
Search ldap/base done
Start LDAP Server: done
Search LDAP binddn done
Sync time: fail
Join Computer Account: done
Stopping univention-directory-listener daemon: done
Sync ldap-backup.secret: done
Check TLS connection: done
Download host certificate: .. done
Restart LDAP Server: done
Sync Kerberos settings: done
Not updating kerberos/adminserver
Configure 01univention-ldap-server-init.inst done
Configure 03univention-directory-listener.inst failed
* Join failed! *
* Contact your system administrator *
* Message: FAILED: 03univention-directory-listener.inst
And in log I see:
File: /etc/ldap/ldap.conf
Could not chdir to home directory /dev/null: Not a directory
scp: /etc/univention/ssl/hostname: Permission denied
scp: /etc/univention/ssl/domain: Permission denied
Restarting ldap server(s).
Stopping ldap server(s): slapd ...done.
Starting ldap server(s): slapd ...failed.
56741980 /etc/ldap/slapd.conf: line 50: <suffix> invalid DN 21 (Invalid syntax) slapschema: bad configuration file!.
I can add that on Master side I see that server by:
udm computers/domaincontroller_slave list
I didn’t have any problems like that when I joined AWS VM to Master. All connection is working between. DNS! Ping! Domains! All is good.
I will be glad for any help.
Thank you,
Rafal
I check different options. I will do it again and not join to UCS Domain by Wizard but later after install. But probably there will be LDAP package missing and more.
