Calendar permissions can not delete
Good day,
After upgrading the system, users can not delete calendar setups. Where do I have to look, what change on controlling permissions over the calendar?
Riley
What calendar are you talking about? There are multiple apps in the Univention Appcenter, which provide a calendar.
OpenXchange Calendar
Riley
Message is : The operation could not be completed due to a concurrent modification. Please reload the data and try again.
 What path , what database holds the calendar  data.   This problem wasnt before upgrade
Riley
