Bug in DHCP setup, system is caching WRONG data
if you setup a DHCP server using the univention portal.
setup a “DHCP: Shared network”
give it a name like 10.10.206.0 255.255.254.0 ,broardcast address…
go into it setup a network
now go back and DELETE the shared network at the top level.
it now has an internal cahed reference to it being a shared network
this time do EXACTLY the same but make it a subnet
now when you go into it to try and make a “dhcp object”, it asks for a SHARED object to be created not
a “GENERAL DHCP pool object”
however if you leave the DHCP screen and go back to the home page ,then navigate BACK into the DHCP pages , THEN it asks for a “GENERAL DHCP pool object”.
so it seems the portal is incorrectly caching the old deleted object and assuming a type from it.
there needs to be some sort of refresh system to clean & rebuild the info on all ADDS & deletes., if you are gonig to allow the user to STAY in teh DHCP screen making & CRITICALLY deleteing and remaking objects.
