I have 2 Univention (KVM) hosts, both version 4.4-0:
Host1 was upgraded from 4.3 (or earlier)
Host2 is new 4.4-0 install
Host1 has br0 br1 br2 configured, all ports (eth0, eth1, eth2, eth3) speed is 1000 Mbits speed. Host1 also has ethtool installed. (and there is script in /etc/network/if-up.d/ethtool something to do with speed)
Host2 has br0 br1 br2 configured, ports (eno1, eno2, eno3) speed is 100 Mbits only. (eno4 unconfigured port speed is 1000 Mbits).
I think what happened is that once I configured bridge ports on Host2, speed dropped to 100 Mbits. ethtool is not installed. And because ethtool is missing, could it be that bridged ports speed was automatically set at 100 Mbit?
I could add unmaintaned repositories, install ethtool and force 1000 speed, however is there a Univention way of doing same?
PS how did I check link speed, example: cat /sys/class/net/eno1/speed
Line speed is handled solely by the kernel without the need for any user space tool. If your interfaces run at 100 Mbit/s, the reason is certainly not the absence of ethtool. Check:
that you’re using Gbit/s-capable cabling,
that your switch actually supports Gbit/s and isn’t a 100 Mbit/s one,
if it’s a managed switch that the switch ports aren’t configured to only allow 100 Mbit/s or that they’re set to a fixed rate instead of auto negotiation.
For our benefit you can enable the “unmaintained” repository on your UCS server and install the ethtool package afterwards. Then run ethtool ano1 and post the output. That might shed some light on what’s happening.
In general UCS only provides ways to configure bridging/bonding/IP addresses, but not hardware properties. If you need to configure your interfaces manually from user space, use the usual ways, e.g. by running the appropriate programs via udev rules.
It is possible that just by some coincidence, three cables in question are bad, but I can only confirm that by replacing them with other cables during out of working hours window.
Switch supports 1Gbits, and
all ports on switch are set to auto negotiation.
on Host2:
$ sudo ethtool eno1
Settings for eno1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: off
Supports Wake-on: g
Wake-on: g
Current message level: 0x000000ff (255)
drv probe link timer ifdown ifup rx_err tx_err
Link detected: yes
$ sudo ethtool eno4
Settings for eno4:
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 4
MDI-X: off
Supports Wake-on: g
Wake-on: g
Link detected: yes
You could try forcing the link speed to 1000 full for the affected interfaces and see if still have connectivity afterwards: ethtool -s eno1 speed 1000 duplex full
Note that you shouldn’t run that over ssh as it’s absolutely possible to disrupt connectivity that way. You must have console access (at least for emergencies) when you try this.
If it does help, configure appropriate udev rules or a systemd service to run the necessary commands during boot.
Having extra Ethernet ports, I decided to run my virtual machines on other ports rather than primary network interface on the host.
Forcing speed with ethtool to 1000 Mbits unfortunately did not work: virtual machines became unavailable on network. I set the speed back to 100 Mbits.
I seen on internet few stackexchange topics with similart problems, when configuring br interface dropped network interface speed to 100 Mbits.
Now that ethtool is installed, I will try
try restarting server during maintenance window maybe this evening, maybe that will help,
will check cables during the week
will configure one more bridge port on spare eno4 interface, which currently shows speed as 1000
