Block Powershell for specific Usergroups
Hello there,
is there any way i can block powershell on windows for certain user groups?
Thanks a lot
Hi @Kasashii
It should be possible to write the policy to the UCS with a joined Windows client using the Windows Active Directory and Policy Manager clients tools and thus distribute it to the clients.
Stolen from here: Group Policy Management - #3 by mjda
I can’t tell you exactly how the policy has to be defined in Windows.
Best
AlteSocke
