Bitwarden and SSO
i installed Bitwarden via UCS and connected it to SAML to get SSO working. But than i found following https://github.com/dani-garcia/bitwarden_rs/issues/1193. When bitwaren_rs is used there is no possible way to get it working?
So is there a Plan to include the official Bitwarden Server so it is possible to use SSO?
Best Regards
Hi @UIptp,
if you have installed bitwarden from the appcenter (e.g. this one https://www.univention.com/products/univention-app-center/app-catalog/bitwarden/), then that is the official Bitwarden implementation.
