Moin,
UCS 4.4.1. Beim Versuch, benno-mailarchiv über das AppCenter zu installieren, erhalten wir nur
24897 actions.install.container.92f2 19-08-26 07:35:05 [ DEBUG]: Calling docker exec -u root 92f2b8dd10c27f2e2e9bc701ff32e8061db59ffa04a3d616e875733df0a7086c /usr/share/univention-docker-container-mode/setup --username Administrator --app benno-mailarchiv --error-file /var/univention/tmp/tmpqvvDIA --password-file /var/univention/tmp/tmp4n7jLh --app-version 2.4.6
24897 actions.install.container.92f2 19-08-26 07:35:05 [ INFO]: Joining
24897 actions.install.container.92f2 19-08-26 07:35:05 [ INFO]: univention-join: joins a computer to an ucs domain
24897 actions.install.container.92f2 19-08-26 07:35:05 [ INFO]: copyright (c) 2001-2019 Univention GmbH, Germany
24897 actions.install.container.92f2 19-08-26 07:35:05 [ INFO]: Search DC Master: done
24897 actions.install.container.92f2 19-08-26 07:35:14 [ INFO]: Check DC Master: done
24897 actions.install.container.92f2 19-08-26 07:36:10 [ INFO]: Search ldap/base done
24897 actions.install.container.92f2 19-08-26 07:36:16 [ INFO]: Search LDAP binddn done
24897 actions.install.container.92f2 19-08-26 07:36:21 [ INFO]: Join Computer Account: done
24897 actions.install.container.92f2 19-08-26 07:37:57 [ INFO]: Check TLS connection: done
24897 actions.install.container.92f2 19-08-26 07:54:54 [ INFO]: Download host certificate: ..............................failed to get host certificate
24897 actions.install.container.92f2 19-08-26 07:54:54 [ INFO]: **************************************************************************
24897 actions.install.container.92f2 19-08-26 07:54:54 [ INFO]: * Join failed! *
24897 actions.install.container.92f2 19-08-26 07:54:54 [ INFO]: * Contact your system administrator *
24897 actions.install.container.92f2 19-08-26 07:54:54 [ INFO]: * Message: Please visit https://help.univention.com/t/8842 for common problems during the join and how to fix them -- failed to get host certificate
24897 actions.install.container.92f2 19-08-26 07:54:54 [ WARNING]: Something went wrong while joining the system
24897 actions.install.container.92f2 19-08-26 07:54:54 [CRITICAL]: Something went wrong while joining the system
24897 packages 19-08-26 07:54:54 [ DEBUG]: Releasing LOCK
24897 actions.install 19-08-26 07:54:54 [CRITICAL]: Setup script failed!
24897 actions.install 19-08-26 07:54:54 [ WARNING]: Aborting...
24897 actions.remove 19-08-26 07:54:54 [ DEBUG]: Calling remove
24897 actions.remove.progress 19-08-26 07:54:54 [ DEBUG]: 0
24897 actions.remove 19-08-26 07:54:54 [ INFO]: Going to remove Benno MailArchiv (2.4.6)
24897 actions.remove 19-08-26 07:54:55 [ DEBUG]: Calling prescript (prerm)
ps aux zeigte ständig diesen Befehl
root 30871 0.0 0.1 22068 6780 ? R 07:52 0:00 /usr/bin/python2.7 /usr/sbin/univention-scp /etc/machine.secret -q -r benno-74286119$@ucs.blank.intranet:/etc/univention/ssl/benno-74286119 benno-74286119$@ucs.blank.intranet:/etc/univention/ssl/benno-74286119.blank.intranet /etc/univention/ssl/
Manuell aufgerufen gabs dann nur
root@ucs:~# /usr/sbin/univention-scp /etc/machine.secret -r benno-74286119$@ucs.blank.intranet:/etc/univention/ssl/benno-74286119 benno-74286119$@ucs.blank.intranet:/etc/univention/ssl/benno-74286119.blank.intranet /etc/univention/ssl/
ssh: Could not resolve hostname benno-74286119ucs.blank.intranet: Name or service not known
Was läuft hier schief?
Der Benno-Support schreibt:
“das scheint nach erster Einblicknahme eher ein UCS-Problem zu sein. Eventuell wird durch ein Benno Paket etwas blockiert. Wenn der Join fehlschlägt, müsste der Univention-Support etwas dazu sagen können.”
