meine Benno-Dienste starten neuerdings nicht mehr. Leider habe ich mit dem unschönen Docker-Setup keinerlei Erfahrungen und weiss nicht weiter:
root@benno:~# univention-app shell benno-mailarchiv
root@benno-21819537:/# /etc/init.d/benno-rest start
[ ok ] Starting benno-rest (via systemctl): benno-rest.service.
root@benno-21819537:/# /etc/init.d/benno-rest status
* benno-rest.service - LSB: Starts the REST interface of Benno Mailarchiv
Loaded: loaded (/etc/init.d/benno-rest; generated; vendor preset: enabled)
Active: active (exited) since Fri 2018-09-21 12:00:36 UTC; 5 days ago
Process: 153 ExecStart=/etc/init.d/benno-rest start (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 4915)
CGroup: /docker/8b0345434faf7c68fa85a468266bf93c5b9c28b15fa3c811168a68bd387a1c52/system.slice/benno-rest.service
Sep 21 12:00:35 benno-21819537 systemd[1]: benno-rest.service: Failed to reset devices.list: Operation not permitted
Sep 21 12:00:35 benno-21819537 systemd[1]: benno-rest.service: Failed to set invocation ID on control group /docker/8b0345434faf…permitted
Sep 21 12:00:35 benno-21819537 systemd[1]: Starting LSB: Starts the REST interface of Benno Mailarchiv...
Sep 21 12:00:36 benno-21819537 benno-rest[153]: Starting Benno REST interface ...
Sep 21 12:00:36 benno-21819537 systemd[1]: Started LSB: Starts the REST interface of Benno Mailarchiv.
Sep 21 12:09:00 benno-21819537 systemd[1]: benno-rest.service: Failed to reset devices.list: Operation not permitted
Sep 21 12:09:00 benno-21819537 systemd[1]: benno-rest.service: Failed to set invocation ID on control group /docker/8b0345434faf…permitted
Hint: Some lines were ellipsized, use -l to show in full.
root@benno-21819537:/# /etc/init.d/benno-archive start
[ ok ] Starting benno-archive (via systemctl): benno-archive.service.
root@benno-21819537:/# /etc/init.d/benno-archive status
● benno-archive.service - LSB: Starts the archiving service of Benno MailArchiv
Loaded: loaded (/etc/init.d/benno-archive; generated; vendor preset: enabled)
Process: 180 ExecStart=/etc/init.d/benno-archive start (code=exited, status=0/SUCCESS)
CGroup: /docker/8b0345434faf7c68fa85a468266bf93c5b9c28b15fa3c811168a68bd387a1c52/system.slice/benno-archive.service
Sep 21 12:00:35 benno-21819537 systemd[1]: benno-archive.service: Failed to set invocation ID on control group /docker/8b0345434…permitted
Sep 21 12:00:35 benno-21819537 systemd[1]: Starting LSB: Starts the archiving service of Benno MailArchiv...
Sep 21 12:00:36 benno-21819537 benno-archive[180]: Starting Benno Archiver ...
Sep 21 12:00:36 benno-21819537 benno-archive[180]: .
Sep 21 12:00:36 benno-21819537 systemd[1]: Started LSB: Starts the archiving service of Benno MailArchiv.
Sep 21 12:09:00 benno-21819537 systemd[1]: benno-archive.service: Failed to reset devices.list: Operation not permitted
Sep 21 12:09:00 benno-21819537 systemd[1]: benno-archive.service: Failed to set invocation ID on control group /docker/8b0345434…permitted
Weis jemand Rat ?
TIA
… fragt man Google zu “Failed to reset devices.list: Operation not permitted” dann stösst man immer wieder aut die “capabilies” die beim initialisieren eines Images mitgegeben werden. Ich meine, dass die NullPointerException eher ein Folge davon ist und nicht die Ursache.
